Using filestorage for images
toco3
Post by toco3 » 15 Dec 2023, 16:38
I like to use AWS S3 / Cloudfront to store images for the products. I installed and configured aus_driver_amazon_s3 to add S3 Storage to TYPO3.
I configured pageTS to use this filestorage for uploads within TYPO3 by default:
options.defaultUploadFolder = 2:/media/
So if I e.g. add a image content elment und just use "upload" the image is stored to this filestorage and delivered via CloudFront.
But Aimeos still uses /uploads folder for uploading images?
How can I configure Aimeos to also use the custom filestorage?
Thank you
Chrisitan
TYPO3 12.4
Aimeos 23-10.2
PHP 8.2
Re: Using filestorage for images
Post by aimeos » 18 Dec 2023, 14:01
Aimeos doesn't use the TYPO3 file abstraction layer due to several problems with that API.
Instead, it uses FlySystem, a lightweight fileystem layer which you can configure to use AWS S3 storage as described here:
https://github.com/aimeos/ai-filesystem
