Grapesjs update
Wall0fDeath
Grapesjs update
Post by Wall0fDeath » 09 Jan 2024, 11:16
Php : 8.2
Os: Debian GNU/Linux 11 (Bullseye)
Aimeos 2022.10.12
Laravel 9.52.16
Dear Aimeos Team,
I would like to replace the grapes.js ( version 0.18 ) built into Aimeos ( 2022.10 ) with the current one (version: 0.21)?
(The table management in the original grapes js seems to be working much better.)
Are there any instructions for this?
Has anyone done this before?
How do I get started?
Re: Grapesjs update
Post by aimeos » 09 Jan 2024, 11:30
First, you have to replace the code in these files with the current code:
./vendor/aimeos/ai-cms-grapesjs/themes/admin/jqadm/grapesjs.js
./vendor/aimeos/ai-cms-grapesjs/themes/admin/jqadm/grapesjs-ext.js
./vendor/aimeos/ai-cms-grapesjs/themes/admin/jqadm/grapesjs.css
Then, you have to check if the GrapesJS API has changed and requires adapting the code.
If you get it to work, we would love to integrate your changes into the core! :-)
