Invalid JSON as result of search for ID "19" in "mshop_attribute_type.i18n"
shainanand
Post by shainanand » 18 Jan 2024, 14:58
Getting this error in the admin dashboard. Any idea what this error is about?
Re: Invalid JSON as result of search for ID "19" in "mshop_attribute_type.i18n"
Post by aimeos » 20 Jan 2024, 14:01
This may happen if you export and reimport the database because then, it's likely that the DEFAULT value for the TEXT column isn't added again. In dev-master, we've already changed that so it's not a problem any more. The patch has been backported to 2023.10.x-dev now, so can you please give it a try by executing:
composer req aimeos/aimeos-core:2023.10.x-dev
