How to overvrwrite base.blade.php and blade template in view folder by extension.
AleksandarJovanovic
Post by AleksandarJovanovic » 21 Jan 2024, 21:45
Aimeos version 2023.10
Php: 8.1
Linux
Dear,
I create own extansion to change some files in project. But i want to use default theme and edit some file from extension not new theme. I create view folder in my extension and copy file from but cant see changes on frontend. I know to must create theme from extension builder and that works, but can i edit from extenson to avoid new theme?
Best regards
Re: How to overvrwrite base.blade.php and blade template in view folder by extension.
Post by aimeos » 23 Jan 2024, 07:47
You don't have to create a new theme to overwrite the base.blade.php. Just copy the file from the ./vendor/aimeos/aimeos-laravel/views/base.blade.php to the ./resources/views/vendor/shop/ directory of your Laravel application:
https://aimeos.org/docs/latest/laravel/ ... -templates
