Config for multiple BCC-Mails?
Webrocker
Post by Webrocker » 22 Jan 2024, 11:21
in the Aimeos Docu (https://aimeos.org/docs/latest/config/c ... cc-email_1) it says:
Type: string|array - E-mail address or list of e-mail addresses
I tried to set this in the TYPO3 extension (planner/cronjob settings). When I state one email address
…bcc-email= my@addre.ss
it works, but what is the supposed way to state it there as an array for multiple adresses?
I tried the TypoScript Array way
 …bcc-email.10 = my@addre.ss
 …bcc-email.20 = other@add.ress
, but then the job fails. I tried other variants like
bcc-email = COA
bcc-email.10 = text
bcc-email.10.value = my@addre.ss
as well, but this also didn't work.
I realize that the bcc-option is not recommended anyway, but in this particular setup is needed to send the mail to other addresses beside the customer.
thank you again for any hints
Re: Config for multiple BCC-Mails?
Post by aimeos » 23 Jan 2024, 11:20
Webrocker wrote: 22 Jan 2024, 11:21 I tried the TypoScript Array way
controller.jobs.order.email.payment.bcc-email {
  0 = my@addre.ss
  1 = other@add.ress
This should be correct but maybe the underlying Symfony Mailer package doesn't work as expected. Normally I would say, these lines of code should be correct according to the docs:
- https://github.com/aimeos/ai-typo3/blob ... #L118-L135
- https://api.typo3.org/12.4/class_t_y_p_ ... ssage.html
Webrocker
Post by Webrocker » 24 Jan 2024, 17:56
aimeos wrote: 23 Jan 2024, 11:20
  0 = my@addre.ss
  1 = other@add.ress
Thank you, this
  0 = my@addre.ss
  1 = other@add.ress
works for me now. yehaa! :-)
