How can I change the dateformat for calendar inputs?
shainanand
Post by shainanand » 23 Jan 2024, 14:14
Currently, the input dates are having the format YYYY-MM-DD. I would like to change it to MM-DD-YYYY. What is the best way to do this?
Re: How can I change the dateformat for calendar inputs?
Post by aimeos » 24 Jan 2024, 09:13
For the admin backend, you can overwrite the Flatpickr configuration in the themes/admin/custom.js file of your own extension:
https://github.com/aimeos/ai-admin-jqad ... in.js#L105
Aimeos.flatpickr.date.altFormat = 'M j, Y';
shainanand
Post by shainanand » 24 Jan 2024, 14:29
Thanks for the response. I came across this js file while debugging but I could not find a way to overwrite the file as this file is in vendor folder in Laravel. Could you please help to suggest the best way to overwrite this file/js code?
Post by aimeos » 24 Jan 2024, 14:36
In ./packages/<yourextension>/themes/admin/custom.js
