Bug with bulk edit
- AleksandarJovanovic
Bug with bulk edit
Aimeos version 2023.10
Php: 8.2
Linux
Dear i have bug when i try to bulk editing multiple product. This is bug to all aimeos instalation that i try on live server and local environment.
When i selected all product the field open but when i try use checkbox the whole panel with edit field just disappear.
(prntscr)
Best regards
Php: 8.2
Linux
(prntscr)
Best regards
- Screenshot from 2024-02-08 09-51-11.png (142.92 KiB) Viewed 49563 times
Re: Bug with bulk edit
We are unsure how to reproduce the issue. Can you record a screencast where you show the problem?
Dear on link u have uplouded video.
https://www.veed.io/view/3b69668d-2d72- ... anel=share
On all my instalation i have same problem.
Tnx
Tnx
We can confirm the problem but haven't found out yet why it happens ...
Thank you for the prompt response, I hope someone will find a solution to this problem. I will definitely follow the forum.
Thanks again.
Thanks again.
We've found the problem and fixed in in aimeos/ai-admin-jqadm:2023.10.x-dev.
Can you please execute this command and test yourself?
composer req aimeos/ai-admin-jqadm:2023.10.x-devProfessional support and custom implementation are available at Aimeos.com
Just tested, and everything works perfectly. Thank you, you're the best
