Extensions for aimeos/aimeos-laravel/views
iwpress
Post by iwpress » 08 Feb 2024, 20:54
aimeos/ai-laravel v.2023.10.4, Laravel v.10.43.0, PHP v.8.1.27, MacOS 14.2
I'm sorry for the complete beginner's question.
I'm reading the documentation, everything is well described about the ai-client-html extension, but I can't figure out where to put the files in my extension (packages/shop) from the aimeos-laravel/views folder to change something in them.
Is it possible that aimeos-laravel as demo data is not expanded at all?
I don't want to use the Extension!
Excuse me, but if I rephrase the question to:
How to change the location of the aimeos-laravel/views folder in the settings config/shop.php (without using the Extension), for example: resources/views/front/shop
I tried the following:
config/shop.php
return [
	'view' => [
		'client' => [
			'html' => [
				'standard' => [
					'name' => 'html',
					'package' => 'resources/views/front/shop'
But it doesn't work :(
BR
Re: Extensions for aimeos/aimeos-laravel/views
Post by aimeos » 10 Feb 2024, 10:51
Laravel expects Blade views overwriting those from packages in ./resources/views/vendor/shop/ and subdirectories:
https://aimeos.org/docs/latest/laravel/ ... -templates
iwpress
Post by iwpress » 10 Feb 2024, 12:23
Thank you, it works.
I'm sorry, for some reason I thought that somewhere in the settings you override the location of your template directory, for example, for Extensions?
I wanted to do something similar.
Best Regards.
