unable to change in CMS
after updating cms content when i press save its showing error -----403-
Forbidden- Access to this resource on the server is denied!
i am working on live server
PHP-8.2
PHP-8.2
Re: unable to change in CMS
Please provide more information about your environment, versions, etc.
PHP version: 8.2
Laravel version: 10
Aimeos version: 2023.10
Environment: windows
Laravel version: 10
Can you create a screencast of the problem?
problem is that when i try to save after some change in cms page or cms content it shows me-- Access to this resource on the server is denied!(403) error. help me to solve this issue. have attached a screenshot
i am am working in live hosting.
- cms.png (70.48 KiB) Viewed 61535 times
This looks like a page generated by the web server. Check it's configuration and the directives in .htaccess file and try to find out, which line is causing the problem.
