Error running upgrade wizard after upgrading from v2021 to v2023
loeffe1
Post by loeffe1 » 08 Mar 2024, 09:17
I am getting this error when running the upgrade wizard
An exception occurred while executing a query: SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'customerref' cannot be null #0 /var/www/html/vendor/doctrine/dbal/src/Connection.php(1943): Doctrine\DBAL\Driver\API\MySQL\ExceptionConverter->convert() #1 /var/www/html/vendor/doctrine/dbal/src/Connection.php(1885): Doctrine\DBAL\Connection->handleDriverException() #2 /var/www/html/vendor/doctrine/dbal/src/Connection.php(1213): Doctrine\DBAL\Connection->convertExceptionDuringQuery() #3 /var/www/html/vendor/aimeos/upscheme/src/Schema/DB.php(267): Doctrine\DBAL\Connection->executeStatement() #4 /var/www/html/vendor/aimeos/aimeos-core/setup/OrderMergeBaseTable.php(34): Aimeos\Upscheme\Schema\DB->exec() #5 /var/www/html/vendor/aimeos/upscheme/src/Up.php(341): Aimeos\Upscheme\Task\OrderMergeBaseTable->up() #6 /var/www/html/vendor/aimeos/upscheme/src/Up.php(328): Aimeos\Upscheme\Up->runTasks() #7 /var/www/html/vendor/aimeos/upscheme/src/Up.php(328): Aimeos\Upscheme\Up->runTasks() #8 /var/www/html/vendor/aimeos/upscheme/src/Up.php(328): Aimeos\Upscheme\Up->runTasks() #9 /var/www/html/vendor/aimeos/upscheme/src/Up.php(172): Aimeos\Upscheme\Up->runTasks() #10 /var/www/html/vendor/aimeos/aimeos-core/Setup.php(84): Aimeos\Upscheme\Up->up() #11 /var/www/html/vendor/aimeos/aimeos-typo3/Classes/Setup.php(148): Aimeos\Setup->up() #12 /var/www/html/vendor/aimeos/aimeos-typo3/Classes/Setup.php(77): Aimeos\Aimeos\Setup::execute() #13 /var/www/html/vendor/typo3/cms-install/Classes/Service/UpgradeWizardsService.php(275): Aimeos\Aimeos\Setup->executeUpdate() #14 /var/www/html/vendor/typo3/cms-install/Classes/Controller/UpgradeController.php(1098): TYPO3\CMS\Install\Service\UpgradeWizardsService->executeWizard() #15 /var/www/html/vendor/typo3/cms-install/Classes/Middleware/Maintenance.php(234): TYPO3\CMS\Install\Controller\UpgradeController->upgradeWizardsExecuteAction() #16 /var/www/html/vendor/typo3/cms-core/Classes/Http/MiddlewareDispatcher.php(111): TYPO3\CMS\Install\Middleware\Maintenance->process() #17 /var/www/html/vendor/typo3/cms-core/Classes/Middleware/NormalizedParamsAttribute.php(41): Psr\Http\Server\RequestHandlerInterface@anonymous->handle() #18 /var/www/html/vendor/typo3/cms-core/Classes/Http/MiddlewareDispatcher.php(162): TYPO3\CMS\Core\Middleware\NormalizedParamsAttribute->process() #19 /var/www/html/vendor/typo3/cms-core/Classes/Http/MiddlewareDispatcher.php(70): Psr\Http\Server\RequestHandlerInterface@anonymous->handle() #20 /var/www/html/vendor/typo3/cms-core/Classes/Http/AbstractApplication.php(80): TYPO3\CMS\Core\Http\MiddlewareDispatcher->handle() #21 /var/www/html/vendor/typo3/cms-install/Classes/Http/Application.php(46): TYPO3\CMS\Core\Http\AbstractApplication->handle() #22 /var/www/html/vendor/typo3/cms-core/Classes/Http/AbstractApplication.php(92): TYPO3\CMS\Install\Http\Application->handle() #23 /var/www/html/public/typo3/install.php(19): TYPO3\CMS\Core\Http\AbstractApplication->run() #24 /var/www/html/public/typo3/install.php(20): {closure}() #25 {main}
Prior to running the upgrade wizard, I executed ./vendor/bin/typo3 aimeos:setup
Re: Error running upgrade wizard after upgrading from v2021 to v2023
Post by aimeos » 08 Mar 2024, 11:00
loeffe1 wrote: 08 Mar 2024, 09:17 I am getting this error when running the upgrade wizard
Guess, it will be the same when you execute the aimeos:setup command from the command line again.
What is the output of "SHOW CREATE TABLE mshop_order"?
loeffe1
Post by loeffe1 » 11 Mar 2024, 14:39
Yes, this will give me the same error:
Here is what SHOW CREATE TABLE mshop_order displays:
CREATE TABLE `mshop_order` (
 `id` bigint(20) NOT NULL AUTO_INCREMENT,
 `baseid` bigint(20) NOT NULL,
 `siteid` varchar(255) COLLATE utf8mb4_bin NOT NULL,
 `channel` varchar(16) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `datepayment` datetime DEFAULT NULL,
 `datedelivery` datetime DEFAULT NULL,
 `statuspayment` smallint(6) DEFAULT -1,
 `statusdelivery` smallint(6) DEFAULT -1,
 `relatedid` varchar(36) COLLATE utf8mb4_bin DEFAULT '',
 `cdate` varchar(10) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `cmonth` varchar(7) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `cweek` varchar(7) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `cwday` varchar(1) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `chour` varchar(2) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `ctime` datetime NOT NULL,
 `mtime` datetime NOT NULL,
 `editor` varchar(255) COLLATE utf8mb4_bin NOT NULL,
 `sitecode` varchar(255) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `customerid` varchar(36) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `invoiceno` varchar(32) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `langid` varchar(5) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `currencyid` varchar(3) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `price` decimal(12,2) NOT NULL DEFAULT 0.00,
 `costs` decimal(12,2) NOT NULL DEFAULT 0.00,
 `rebate` decimal(12,2) NOT NULL DEFAULT 0.00,
 `tax` decimal(14,4) NOT NULL DEFAULT 0.0000,
 `taxflag` smallint(6) NOT NULL DEFAULT 1,
 `customerref` varchar(255) COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 `comment` text COLLATE utf8mb4_bin NOT NULL DEFAULT '',
 PRIMARY KEY (`id`),
 KEY `idx_msord_sid_mtime_pstat` (`siteid`,`mtime`,`statuspayment`),
 KEY `idx_msord_sid_mtime_dstat` (`siteid`,`mtime`,`statusdelivery`),
 KEY `idx_msord_sid_dstatus` (`siteid`,`statusdelivery`),
 KEY `idx_msord_sid_ddate` (`siteid`,`datedelivery`),
 KEY `idx_msord_sid_pdate` (`siteid`,`datepayment`),
 KEY `idx_msord_sid_editor` (`siteid`,`editor`),
 KEY `idx_msord_sid_cdate` (`siteid`,`cdate`),
 KEY `idx_msord_sid_cmonth` (`siteid`,`cmonth`),
 KEY `idx_msord_sid_cweek` (`siteid`,`cweek`),
 KEY `idx_msord_sid_cwday` (`siteid`,`cwday`),
 KEY `idx_msord_sid_chour` (`siteid`,`chour`),
 KEY `fk_msord_baseid` (`baseid`),
 KEY `idx_msord_sid_ctime_pstat` (`siteid`,`ctime`,`statuspayment`),
 KEY `idx_msord_channel_sid` (`channel`,`siteid`),
 KEY `idx_msord_custid_sid` (`customerid`,`siteid`),
 KEY `idx_msord_custid_scode` (`customerid`,`sitecode`),
 KEY `idx_msord_ctime_pstat_sid` (`ctime`,`statuspayment`,`siteid`),
 KEY `idx_msord_mtime_pstat_sid` (`mtime`,`statuspayment`,`siteid`),
 KEY `idx_msord_mtime_dstat_sid` (`mtime`,`statusdelivery`,`siteid`),
 KEY `idx_msord_dstat_sid` (`statusdelivery`,`siteid`),
 KEY `idx_msord_ddate_sid` (`datedelivery`,`siteid`),
 KEY `idx_msord_pdate_sid` (`datepayment`,`siteid`),
 KEY `idx_msord_editor_sid` (`editor`,`siteid`),
 KEY `idx_msord_cdate_sid` (`cdate`,`siteid`),
 KEY `idx_msord_cmonth_sid` (`cmonth`,`siteid`),
 KEY `idx_msord_cweek_sid` (`cweek`,`siteid`),
 KEY `idx_msord_cwday_sid` (`cwday`,`siteid`),
 KEY `idx_msord_chour_sid` (`chour`,`siteid`),
 CONSTRAINT `fk_msord_baseid` FOREIGN KEY (`baseid`) REFERENCES `mshop_order_base` (`id`) ON DELETE CASCADE ON UPDATE CASCADE
) ENGINE=InnoDB AUTO_INCREMENT=29616 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_bin
Post by aimeos » 12 Mar 2024, 08:23
Can you please update:
composer req aimeos/aimeos-core:2023.10.x-dev
We've changed the customerref column to allow NULL values again in the schema.
loeffe1
Post by loeffe1 » 20 Mar 2024, 10:48
Thanks, that fixed it!
