FR: BE - Category - Product listing - label not id
sieg01
Post by sieg01 » 07 Apr 2024, 09:32
Hi devs.
I have a feature request from a user POV.
When opening a Category in the BackEnd.
And look at products within a Category, then it will make life much easier (and save lots of time) if Aimeos would display the product name instead of the product id.
So if Aimeos would read and display "label" from database table "mshop_product" instead of "id".
Do you agree?
Re: FR: BE - Category - Product listing - label not id
Post by aimeos » 07 Apr 2024, 13:13
Agreed but the sub-panel must be completely rewritten for that because it also doesn't work with e.g. ElasticSearch too. It's on our list of todos.
sieg01
Post by sieg01 » 08 Apr 2024, 02:50
aimeos wrote: 07 Apr 2024, 13:13 Agreed but the sub-panel must be completely rewritten for that because it also doesn't work with e.g. ElasticSearch too.
I c. Means it needs some time..
aimeos wrote: 07 Apr 2024, 13:13 It's on our list of todos.
Ok,
so you already had it on the radar.
Thanks.
