I don't understand the new product attributes layout
kdim95
Post by kdim95 » 12 Apr 2024, 17:27
Laravel framework version: 11.3.1
Aimeos Laravel version: 2023.10.8
PHP Version: 8.2.17
Environment: Linux
Please help me to understand why the new admin panel for attributes looks like this.
When I add a new attribute type, there is a section for each attribute, where you can select the attribute type again?
In older versions, you had a section only for variant attributes, normal attributes and hidden attributes.
You had to pick in which section to place the attributes in, select the attribute type, then the value.
Best regards
Re: I don't understand the new product attributes layout
Post by aimeos » 15 Apr 2024, 07:12
It's still the same as before but the "custom" and "configurable" parts from the former "Options" panel have been merged into the "Characteristics" panel. Now, all attribute types are available there.
If you add a new product list type for attributes, they will generate a new part in the "Characteristics" panel you can can dynamically add new list types. In each part, you select the attribute type first and then one of the offered values.
kdim95
Post by kdim95 » 26 Apr 2024, 22:37
I understand my error, it was indeed additionally added product list types from a wrong XML import scheme.
