Custom.css changes arent working
parkktech
Post by parkktech » 16 Apr 2024, 01:59
Hello guys,
I'm new here but hope to do a lot with this package. But first I need to figure out how to properly extend it.
I was able to build a package gemcopro-core and extend the admin menu in the config > admin.php however when I add my changes to get the icon into the custom.css it's not showing. In fact no changes I make there are being reflected.
I also disabled the cache for development.
Is there a special command I need to run to rebuild the css?
I'm sure I'm missing something simple here.
kdim95
Re: Custom.css changes arent working
Post by kdim95 » 16 Apr 2024, 11:17
Check the following:
  • You are editing the CSS located at your-extension/themes/admin/jqadm/custom.css
  • You have a manifest.php in the root of your extension with this config:
    	'custom' => [
    		'admin/jqadm' => [
    			'manifest.jsb2',
  • You have a manifest.jsb2 in the root of your extension with this config:
    "pkgs": [{
    		"name": "your-extension CSS",
    		"file": "your-extension.css",
    		"isDebug": true,
    		"fileIncludes": [{
    			"text": "custom.css",
    			"path": "themes/admin/jqadm/"
  • You don't have cache (refresh with CTRL+SHIFT+R)
Best regards
parkktech
Post by parkktech » 16 Apr 2024, 17:24
Yes, I used your extension builder so it appears that is already in place.
        'custom' => [
                'admin/jqadm' => [
                        'manifest.jsb2',
                'controller/jobs' => [
                        'src',
Yes here is manifest.jsb
        "projectName": "gemcopro-core",
        "licenseText": "proprietary",
        "pkgs": [{
                "name": "gemcopro-core CSS",
                "file": "gemcopro-core.css",
                "isDebug": true,
                "fileIncludes": [{
                "name": "gemcopro-core JS",
                "file": "gemcopro-core.js",
                "isDebug": true,
                "fileIncludes": [{
                        "text": "custom.js",
        "resources" : []
I guess a caviot is we installed this in an existing larvel site with the intention of brining some of the customizations into Aimeos.
I'm nit seeing anything different than you posted.
Do you have any other suggestions?
Post by aimeos » 17 Apr 2024, 08:01
Did you add your extension to the ./packages/ directory and installed it via composer?
https://aimeos.org/docs/latest/developer/extensions/
parkktech
Post by parkktech » 17 Apr 2024, 19:12
Of course, and all the menu items are showing from my extension.
It's just the CSS change isn't taking.
custom.css contents
 * Custom gemcopro-core CSS
/* Gemco Admin Menu*/
.aimeos .main-sidebar .menuitem-gemco i.icon::before {
    content: "\F3E5";
.aimeos .main-sidebar .menuitem-settings i.icon::before {
    content: "\F56B";
parkktech
Post by parkktech » 18 Apr 2024, 21:18
Ok, I got it working. It turns out your extension builder added the
to the manifest. But when looking at some other extensions like grape they use "file": "index-css",
When I switched to this it started working.
Can you guys better explain this name and file logic?
Thanks, Jason
Post by aimeos » 19 Apr 2024, 12:42
Which Aimeos version do you use?
peter69
Post by peter69 » 07 Jun 2024, 05:33
I have the same issue. It only works if I set the 'file' to 'index-css'.
I'm using:
'aimeos/aimeos-laravel': '~2024.04'
'laravel/framework': '^11.0'
Post by aimeos » 07 Jun 2024, 06:17
You need a 2024 version of the Aimeos extension generated here: https://aimeos.org/extensions
If you update from earlier versions, please make sure that the "file" properties in the "pkgs" section of the manifest.jsb2 file are "index-css" respectively "index-js".
peter69
Post by peter69 » 10 Jun 2024, 15:04
Got it!, Thanks!
