Overriding Status Names
jafo66
Post by jafo66 » 16 Apr 2024, 19:00
I would like to change the name of the statuses used in the admin panels. This code seems pretty standard:
          'status' => ['op' => '==', 'type' => 'select', 'val' => [
		'1' => $this->translate( 'mshop/code', 'status:1' ),
		'0' => $this->translate( 'mshop/code', 'status:0' ),
		'-1' => $this->translate( 'mshop/code', 'status:-1' ),
		'-2' => $this->translate( 'mshop/code', 'status:-2' ),
I tried overriding in the shop.php under i18n, en, mshop but that didn't work. I also tried adding values to mshop, i18n, en which didn't work.
Can you let me know how I would make that change?
Re: Overriding Status Names
Post by aimeos » 18 Apr 2024, 11:29
The translation domain is "mshop/code":
'i18n' => [
    'en' => [
        'mshop/code' => [
            'status:1' => ['Active'],
See also: https://aimeos.org/docs/latest/laravel/ ... anslations
jafo66
Post by jafo66 » 18 Apr 2024, 14:35
Thanks!
