overwrite default data setup/site
WladimirAvila
Post by WladimirAvila » 05 May 2024, 17:31
Hi everyone, I´m trying to setup a Spanish multishop site with Aimeos.
When creating a user/site, the file https://github.com/aimeos/aimeos/blob/m ... er.php#L72 calls the ai-core and this extension runs https://github.com/aimeos/aimeos-core/t ... fault/data
I need to populate the database with the same "data" folder, but with my custom folder in Spanish.
How will it be possible to change only this path or do I've to overwrite the whole aimeos-core instead?
Thanks for any help or suggestion, I'm new in Aimeos, and all the detailed answers will be welcome.
I'm using aimeos/aimeos in the latest version over PHP 8.2
Wlad
Re: overwrite default data setup/site
Post by aimeos » 06 May 2024, 09:11
You can add own data by creating setup tasks in your own Aimeos extension:
https://aimeos.org/docs/latest/infrastr ... migrations
The default demo data is only added to the first "default" site and only if you use "--option=setup/default/demo:1" when executing the "artisan aimeos:setup" command.
