Change the order of subparts
jafo66
Post by jafo66 » 14 May 2024, 21:17
I've added a subpart to the products, but I was wondering if there was a way to have it ordered (similar to the menu does) where it shows up higher in the list of subparts?
Thanks!
Re: Change the order of subparts
Post by aimeos » 15 May 2024, 06:49
Yes, overwrite this configuration in your ./config/shop.php and add your subparts where it should be displayed:
https://github.com/aimeos/ai-admin-jqad ... #L123-L138
