List type config is empty
thestranger
Post by thestranger » 06 Jun 2024, 04:56
Aimeos 2024.04
Laravel 11
PHP 8.2
List type config is empty.
private array $beconfig = [
	'xplicit.courier.type' => [
		'code' => 'xplicit.courier.type',
		'internalcode' => 'xplicit.courier.type',
		'label' => 'Courier Type',
		'type'=> 'select',
		'internaltype'=> 'string',
		'default' => ['option1', 'option2'],
		'required' => true,
I also tried with integer. Am I missing something? Should I be handling how lists look in backend? I'm confused.
Re: List type config is empty
Post by aimeos » 06 Jun 2024, 10:32
Thank you for your hint!
The problem has been fixed and a new version is available. Please run "composer up" to get the fixed version.
thestranger
Post by thestranger » 07 Jun 2024, 00:26
It is still empty. I did try to clear cache just in case it was that. Could you tell me which files handle the creation of the select type so I could check? Also I did notice list and map just display the default values, there is no selection, or maybe I am reading it wrong?
Edit: same thing on a new installation
Post by aimeos » 07 Jun 2024, 07:28
The change is in this file/commit: https://github.com/aimeos/ai-admin-jqad ... 7d551e2105
In your new screenshot, you aren't using "select" as type but "map" instead. To save a map, please click on the "check" button first before clicking on the "Save" button.
thestranger
Post by thestranger » 09 Jun 2024, 07:04
Well, that doesn't matter anymore, the changes finally kicked in and it works now, thank you for your help.
Edit: it might matter, in the first image i was using select type and in the second image I was using list type which for some reason was looking exactly the same as map type. Just checked and it still looks the same, but I can work with select.
Post by aimeos » 09 Jun 2024, 16:25
For the backend, "list" and "map" are the same as documented here:
https://aimeos.org/docs/latest/provider ... figuration
