Attribute type translations do not get saved
thestranger
Post by thestranger » 07 Jun 2024, 03:23
Aimeos 2024.04
Laravel 11
PHP 8.2
As in the title, attribute type translations do not get saved, when i press save it just dissapears and it doesn't work in frontend either. Tested both on main project and new installation. Also it doesn't throw any errors.
Re: Attribute type translations do not get saved
Post by aimeos » 07 Jun 2024, 10:58
Thanks for the hint! The problem has been fixed in aimeos/ai-admin-jqadm 2024.04 branch. To get the latest code until it's tagged for the new release, use:
composer req aimeos/ai-admin-jqadm:2024.04.x-dev
thestranger
Post by thestranger » 09 Jun 2024, 07:15
Thank you, it works.
