Seeking Advice on Adding New Elements to Aimeos Page Builder in CMS
notdot
Post by notdot » 13 Jun 2024, 07:29
I'm currently working on a project where I need to add new elements to the page builder in the Aimeos CMS. I've got everything set up locally and have been exploring the available documentation, but I'd love to hear any advice or tips from the community on how to best approach this task. Here’s a brief overview of my local setup:
  • PHP Version: 8.2.12
  • Aimeos Version: 2024.x
  • Aimeos Setup: Installed via Composer in a Laravel project
  • Custom Theme: Created using the Aimeos extension generator and installed successfully
  • Current Objective: Enhance the CMS page builder by adding custom elements
I am specifically looking for guidance on:
  • The best practices for adding new elements to the page builder like adding icons or lists.
  • Any specific files or directories that should be modified or extended.
  • Examples or templates of custom elements that have been successfully integrated.
  • Any recommended tools or resources that could facilitate this task.
Thank you in advance for your help and suggestions!
Re: Seeking Advice on Adding New Elements to Aimeos Page Builder in CMS
Post by aimeos » 13 Jun 2024, 10:55
Here your can see the existing blocks:
https://github.com/aimeos/ai-cms-grapes ... #L233-L396
Here are the components defined if the blocks need some JS code to work:
https://github.com/aimeos/ai-cms-grapes ... #L399-L834
