Export sitemap for each tennant separately
AleksandarJovanovic
Post by AleksandarJovanovic » 16 Jun 2024, 13:41
How can I create a sitemap for each tenant separately? When I use the command php artisan aimeos:jobs product/export/sitemap <site code>, it exports only for that tenant, but each time I change the <site code>, it updates the existing one. How can I create one for each tenant separately and have it work consistently?
Thank you in advance for your response.
Aleksandar
Aimeos 2024.04
Ubuntu
Php 8.2
Re: Export sitemap for each tennant separately
Post by aimeos » 17 Jun 2024, 22:06
You are right, that's a problem because the sitemaps are overwritten. Until it's fixed, you can extend the job controller and overwrite the "filename()" and "indexFilename()" methods here to include the site code:
https://github.com/aimeos/ai-controller ... #L289-L314
Post by aimeos » 20 Jun 2024, 07:35
This has been fixed in dev-master now and will be part of 2024.07+
