Affected versions of CVE-2024-36811
danielsiepmann
Post by danielsiepmann » 20 Jun 2024, 06:20
Hey,
we saw that CVE-2024-36811 has two different info regarding the affected versions.
https://github.com/advisories/GHSA-cr7j-rwmv-vgch states: Affected versions < 2024.04.5,
https://github.com/ssshah2131/CVE/blob/main/Aimeos_RCE states: aimeos-core version < 2024.04.5 as well as Vulnerable Versions: >= 2024.04.1, < 2024.04.5.
Can you tell us which of those two info is correct? And maybe streamline the info? Right now the GitHub advisory is triggering a composer audit for packages < 2024.04.5.
Re: Affected versions of CVE-2024-36811
Post by aimeos » 20 Jun 2024, 07:03
danielsiepmann wrote: 20 Jun 2024, 06:20 we saw that CVE-2024-36811 has two different info regarding the affected versions.
Only 2024.04.1 to 2024.04.4 are affected. The Github notice was created by a security scanner which added the vulnerability via MITRE to the CVE database but with wrong versions and Github used that for creating a security advisory automatically. We've already submitted a change request and hope it will get fixed soon.
danielsiepmann
Post by danielsiepmann » 20 Jun 2024, 07:33
Thanks for clarification and for taking care this will be fixed on GitHubs end.
