How can I insert an image in the admin panel using the CKEditor 5 editor
Slava
Post by Slava » 05 Jul 2024, 07:32
How can I insert an image in the admin panel using the CKEditor 5 editor when creating a text field?
Screenshot from 2024-07-05 10-29-11.png (11.69 KiB) Viewed 17257 times
Re: How can I insert an image in the admin panel using the CKEditor 5 editor
Post by aimeos » 08 Jul 2024, 14:08
We don't support images in texts by default because it leads to a lot of problems managing those data and unstructured data isn't suited for the JSON:API at all. We recommend to upload the image in the "Media" tab and decide in the frontend template where to render the texts/images and how.
