aimeos headless
Muhammad-Nawlo
aimeos headless
Post by Muhammad-Nawlo » 16 Jul 2024, 02:06
Hi I am new to aimeos headless,I just want to know that all the features of aimeos are supported via jsonapi or not
like theming and b2b extension,If ok How can I know all apis
php 8.1
aimeos-laravel 2024.07
aimeoscom/ai-site 2024.07
Re: aimeos headless
Post by aimeos » 17 Jul 2024, 11:52
Yes, the Aimeos headless distribution supports all Aimeos features and extensions but obviously not anything frontend related like themeing as you build your frontend yourself if you use only the JSON API.
Muhammad-Nawlo
Re: aimeos headless
Post by Muhammad-Nawlo » 17 Jul 2024, 12:03
Thank you for answering, How can I get all availabel apis
for example: availabel locales,availabel sites and so on
