CSS Not showing up on initial installation on laravel 5.2
afoster009
Hey Gang, I just installed the aimeos package on a fresh installation of laravel 5.2 and no CSS seems to be showing up although the components seem to be there. I also dont under stand what it means by "adapt your main Blade template in resources/views/app.blade.php" when there is no app.blade.php view.
any help on what exactly i am suppose to be configuring? Everything is default from the initial installation.
Below is a screen shot
- screenie.PNG (59.52 KiB) Viewed 7311 times
Re: CSS Not showing up on initial installation on laravel 5.
You have to create the file with the content shown in https://github.com/aimeos/aimeos-laravel#setupafoster009 wrote: I also dont under stand what it means by "adapt your main Blade template in resources/views/app.blade.php" when there is no app.blade.php view.
Then it will work as expected.
afoster009
I coppied that content into the welcome.blade.php file that comes with the laravel installation and its still not working
You need to paste it into the new app.blade.php file
