checkout steps
hyalcin
checkout steps
Post by hyalcin » 09 Aug 2024, 13:27
After making the checkout steps onepage, when I click the back button on the address form, it returns to the basket step, but I do not use basket. Also, on the address page, the next button runs shop/checkout/process and I get the error [DOM] Multiple forms should be contained in their own form elements; break up complex forms into ones that represent a single action: (More info: https://goo.gl/9p2vKq) <form class=​"container-xxl" method=​"POST" action=​"/​shop/​checkout/​process">​…​</form>​
Thanks in advance for your help.
Re: checkout steps
Post by aimeos » 13 Aug 2024, 04:43
Did you adapt the checkout templates? By default, there's only one form for all checkout steps.
hyalcin
Re: checkout steps
Post by hyalcin » 14 Aug 2024, 09:41
Yes, I added new fields to the form.
