Please help me choose: Aimeos Laravel vs. Aimeos Headless
johnnuman
Post by johnnuman » 17 Aug 2024, 17:22
I need to develop a PoD store with couple of thousand products. The frontend will be vue Storefront. I need to decide for backend should I choose Headless or standard Laravel version. In future it may evolve into a multi-vendor SaaS platform but at the start that is not a requirement.
Secondly, I have reviewed the Vue Storefront integration link in the extensions section. That seems quite old and not maintained anymore and moreover it is not targeting the latest VSF version. Is there some other extension available for it which is more up-to-date or atleast actively maintained? Or will I have to start from scratch for it?
I appreciate your time and effort in guiding me. Thanks.
Re: Please help me choose: Aimeos Laravel vs. Aimeos Headless
Post by aimeos » 20 Aug 2024, 06:55
If you want to use Vue Storefront, than you can use the existing integration but have to fix some things in the integration. It's a 3rd party integration which needs some love.
With any PWA in the frontend, the Aimeos Headless distribution is best suited as base:
https://github.com/aimeos/aimeos-headless
