Set a custom price for a product when added to cart
EmanueleFantin
Post by EmanueleFantin » 20 Aug 2024, 09:58
Hi, I created a "custom sticker" product that has several attributes (color, font, size) that contribute to the price calculation.
So for example a 20x50 cm product costs €10
a 30x70 product costs €12.
I then created a plugin that is called at the addProduct.before event, here is the simple code:
<?php
namespace Aimeos\MShop\Plugin\Provider\Order;
use Illuminate\Support\Facades\Config;
class CalcPriceAdesivi
extends \Aimeos\MShop\Plugin\Provider\Factory\Base
implements \Aimeos\MShop\Plugin\Provider\Iface, \Aimeos\MShop\Plugin\Provider\Factory\Iface
    public function register(\Aimeos\MShop\Order\Item\Iface $p): \Aimeos\MShop\Plugin\Provider\Iface
        $plugin = $this->object();
        $p->attach($plugin, 'addProduct.before');
        return $this;
    public function update(\Aimeos\MShop\Order\Item\Iface $p, string $action, $value = null)
        $num_prodotti = count($p->getProducts()->toArray());
        if ($value['order.product.prodcode'] == Config::get('shop.adesivi.product_name')) {
            $price = $value->getPrice();
            $price->setValue(....FORMULA FOR CALCULATE THE PRICE.....);
            $value->setPrice($price);
        return $value;
The code works and sets the correct price.
But if I create a second sticker that has a different cost, it sets the same price to all the products.
Does anyone know how I could solve this problem? Maybe I don't have to use a plugin but do something else?
Thanks to everyone in advance
Re: Set a custom price for a product when added to cart
Post by aimeos » 20 Aug 2024, 10:02
Use configurable attributes which can have own prices that add up to the total price of the product when selected. Thus, you don't need a basket plugin for custom calculation.
EmanueleFantin
Post by EmanueleFantin » 20 Aug 2024, 10:32
The thing is that the price depends on a calculation made by the software based on the area of ​​the sticker (which in turn depends on the font and the length of the written text).
So I don't have a parameter that determines the price based on something chosen by the user (such as the size of a shirt).
The price must be a hidden field or set when adding to the cart, so that the user cannot change it.
Is this possible with configurable attributes? I can't find it in the documentation...
Post by aimeos » 20 Aug 2024, 11:46
In that case, the basket plugin is the only option. You have to calculate the price based on the attributes of each product.
Also, don't mix Laravel and Aimeos code in basket plugins. You can configure the product code the plugin should use in the plugin config itself.
EmanueleFantin
Post by EmanueleFantin » 20 Aug 2024, 14:34
Thanks for the advice not to mix the code, I will fix it later.
The problem is that the price I calculate is applied to ALL the products of the same type that are in the cart.
I am trying to apply it only to the last insert, but it does not work:
        //count products in basket
        //iterate products in basket
        foreach ($p->getProducts() as $key => $item_product) {
            //IF IT'S THE LAST PRODUCT ADDED I CHANGE THE PRICE
            if($key == ($num_prodotti-1)){
                    $price->setValue(11);
        return $value;
Any advice?
Post by aimeos » 21 Aug 2024, 11:58
Update the price only for the order product contained in $value and don't loop over all order products
EmanueleFantin
Post by EmanueleFantin » 22 Aug 2024, 09:18
Hi, it was the original solution, but it gives me the same result.
            $price->setValue(12.26);
            Log::debug(print_r($value, true));
        return $value;
I made a video: as you can see the first product costs €14.64.
The second is modified and changes the price to €12.26.
But when I add it, both prices are modified!
It's as if Aimeos somewhere (I don't know where) set the modification to all products of the same type, and not just to the specific item in the cart.
https://www.emanuelefantin.it/assets/tmp/videonk.mp4
This thing is driving me crazy! :roll:
Post by aimeos » 24 Aug 2024, 15:03
What is the output of the logging in your basket plugin?
EmanueleFantin
Post by EmanueleFantin » 25 Aug 2024, 10:34
First product added (14.64 €):
Log after second product added (13.21 €):
[2024-08-25 10:33:09] local.DEBUG: Aimeos\MShop\Order\Item\Product\Standard Object
    [available:protected] => 1
    [modified:protected] => 1
    [bprefix:protected] => order.product.
    [type:protected] =>
    [bdata:protected] => Array
            [order.product.siteid] => 1.
            [last_google_update] =>
            [order.product.prodcode] => adesivo-custom
            [order.product.productid] => 50621
            [order.product.type] => default
            [order.product.scale] => 1
            [order.product.target] => adesivi.builder
            [order.product.name] => Scritta adesiva personalizzata
            [order.product.mediaurl] => 1.d/product/b/2/b27568da_06840c86_file-name-53.webp?v=20240813141403
            [order.product.vendor] => NautiKing
            [order.product.quantity] => 1
            [order.product.stocktype] => default
            [order.product.timeframe] =>
    [products:Aimeos\MShop\Order\Item\Product\Base:private] => Array
    [attributes:Aimeos\MShop\Order\Item\Product\Base:private] => Array
            [0] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                    [bprefix:protected] => order.product.attribute.
                    [type:protected] =>
                            [order.product.attribute.siteid] => 1.
                            [order.product.attribute.attributeid] => 30
                            [order.product.attribute.name] => Colore
                            [order.product.attribute.code] => text
                            [order.product.attribute.value] => blue
                            [order.product.attribute.type] => custom
                            [order.product.attribute.quantity] => 1
            [1] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                    [type:protected] =>
                            [order.product.attribute.attributeid] => 31
                            [order.product.attribute.name] => Font
                            [order.product.attribute.value] => caramel
            [2] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                    [type:protected] =>
                            [order.product.attribute.attributeid] => 32
                            [order.product.attribute.name] => Testo
                            [order.product.attribute.value] => RM 012345 X
            [3] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                    [type:protected] =>
                            [order.product.attribute.attributeid] => 33
                            [order.product.attribute.name] => Altezza
                            [order.product.attribute.value] => 20
            [4] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                    [type:protected] =>
                            [order.product.attribute.attributeid] => 34
                            [order.product.attribute.name] => Dimensione
                            [order.product.attribute.value] => 79x20cm
            [5] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                    [type:protected] =>
                            [order.product.attribute.attributeid] => 35
                            [order.product.attribute.name] => UUID
                            [order.product.attribute.value] => 1724581984.007
    [attributesMap:Aimeos\MShop\Order\Item\Product\Base:private] => Array
            [custom] => Array
                    [text] => Array
                            [30] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                                    [type:protected] =>
                            [31] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                                    [type:protected] =>
                            [32] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                                    [type:protected] =>
                            [33] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                                    [type:protected] =>
                            [34] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                                    [type:protected] =>
                            [35] => Aimeos\MShop\Order\Item\Product\Attribute\Standard Object
                                    [type:protected] =>
    [price:Aimeos\MShop\Order\Item\Product\Base:private] => Aimeos\MShop\Price\Item\Standard Object
            [bprefix:protected] => price.
            [type:protected] =>
                    [price.id] => 50649
                    [price.siteid] => 1.
                    [price.type] => default
                    [price.currencyid] => EUR
                    [price.domain] => product
                    [price.label] =>
                    [price.quantity] => 1
                    [price.value] => 13.21
                    [price.costs] => 0.00
                    [price.rebate] => 0.00
                    [price.taxrate] => {"tax":"22.00"}
                    [price.status] => 1
                    [price.mtime] => 2024-08-22 14:35:24
                    [price.ctime] => 2024-08-22 14:13:06
                    [price.editor] => fantin.emanuele@gmail.com
                    [price.taxrates] => Array
                            [tax] => 22.00
                    [.currencyid] => EUR
                    [.precision] => 2
                    [price.taxflag] => 1
            [precision:Aimeos\MShop\Price\Item\Base:private] => 2
            [listPrepared:Aimeos\MShop\Price\Item\Base:private] =>
            [listItems:Aimeos\MShop\Price\Item\Base:private] => Array
            [listRefItems:Aimeos\MShop\Price\Item\Base:private] => Array
            [listRmItems:Aimeos\MShop\Price\Item\Base:private] => Array
            [listRmMap:Aimeos\MShop\Price\Item\Base:private] => Array
            [listMap:Aimeos\MShop\Price\Item\Base:private] => Array
            [listMax:Aimeos\MShop\Price\Item\Base:private] => 0
            [propItems:Aimeos\MShop\Price\Item\Base:private] => Array
            [propRmItems:Aimeos\MShop\Price\Item\Base:private] => Array
            [propMax:Aimeos\MShop\Price\Item\Base:private] => 0
            [currencyid:Aimeos\MShop\Price\Item\Standard:private] => EUR
            [tax:Aimeos\MShop\Price\Item\Standard:private] =>
    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
                            [order.product.attribute.value] => arial
                    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
                            [order.product.attribute.value] => 130x20cm
                    [type:protected] =>
                            [order.product.attribute.value] => 1724581894.823
            [custom] => Array
                    [text] => Array
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
            [type:protected] =>
                    [price.id] => 50649
                    [price.label] =>
                    [price.status] => 1
                            [tax] => 22.00
                    [.precision] => 2
    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
                    [type:protected] =>
            [custom] => Array
                    [text] => Array
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
                                    [type:protected] =>
            [type:protected] =>
                    [price.id] => 50649
                    [price.label] =>
                    [price.status] => 1
                            [tax] => 22.00
                    [.precision] => 2
After second as always I have both products in cart at 13,21 €
Post by aimeos » 27 Aug 2024, 19:54
Hard to say. The price of all products could only change if you set it for all products or if the price item is the same object (which can not be the case here).
