Change product custom atttribute value in basket
lockhart97
Post by lockhart97 » 26 Aug 2024, 04:17
Laravel: 11.0
Aimeos: 2024.04
PHP: 8.2
Environment: Linux
I have a custom attribute which I set to some value when adding product to cart. After the product is added to cart I am not able to update the value for that attribute. In documentation its mentioned that we can update only quantity of the product. Is it possible to update product's custom attribute value as well?
I am using JSON APIs
Re: Change product custom atttribute value in basket
Post by aimeos » 27 Aug 2024, 19:55
Only if you delete the product and add it again. Otherwise, only quantity updates are possible.
lockhart97
Post by lockhart97 » 30 Aug 2024, 05:25
I have created a basket plugin to manage this. SO I can now update a specific custom attribute as required by my application. Thanks.
