How can I create a custom api for product detail?
Jairus34
Post by Jairus34 » 28 Aug 2024, 08:09
Enviroment:
Aimeos: dev-master
Laravel: 11
Mac OS
Hi community,
I'm currently working on a system with a separate front end using React Next.js. We're utilizing the Aimeos JSON API to fetch data, but certain data points need to be formatted before being sent to the front end.
How can I create a custom API for a single product in this setup? Is the process similar to Laravel, where you:
1. Create a controller
2 Define the API route in app/routes/api.php
Does this approach apply here as well?
Thanks in advance for your help!
Re: How can I create a custom api for product detail?
Post by aimeos » 29 Aug 2024, 10:22
The Laravel approach works but we don't recommend that way. You get all data you need from the existing Aimeos JSON:API and all transformations of the data for displaying it should be done in your JS frontend application.
