Issue at multi site's creation
mohan
Post by mohan » 02 Sep 2024, 07:37
I am using Ubuntu 20.04.6 LTS with PHP 8.1
I have followed all the steps outlined in the Aimeos documentation for customizing multiple shops (https://aimeos.org/docs/latest/laravel/ ... iple-shops), available at this link. I successfully created a site named "site1" and set up the admin credentials, which work fine. However, when I attempt to access the frontend at https://mydomain/site1, I receive the error "Locale item for site 'site1' not found," and when trying https://mydomain/site1/shop, I get a 404 error. Could you provide a detailed explanation on how to properly create and access multiple sites in Aimeos?
Re: Issue at multi site's creation
Post by aimeos » 03 Sep 2024, 18:57
In the backend, go to the Locale > Locale panel and add the language/currency combination that should be allowed for that site: https://aimeos.org/docs/latest/manual/locales/
mohan
Post by mohan » 04 Sep 2024, 05:06
Thank you. I have set up multi-site routing using subdomains with the following configurations:
Main Domain: aimeos.selldesk.in
Subdomain: aimeos1.selldesk.in
I created a site named 'aimeos1' and added the following configurations:
In config/shop.php:
'routes' => [
'admin' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'admin', 'middleware' => ['web']],
'jqadm' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'admin/jqadm', 'middleware' => ['web', 'auth']],
'graphql' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'admin/graphql', 'middleware' => ['web', 'auth']],
'jsonadm' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'admin/jsonadm', 'middleware' => ['web', 'auth']],
'jsonapi' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'jsonapi', 'middleware' => ['web', 'api']],
'account' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'profile', 'middleware' => ['web', 'auth']],
'default' => ['domain' => '{site}.yourdomain.com', 'prefix' => 'shop', 'middleware' => ['web']],
'update' => ['domain' => '{site}.yourdomain.com'],
In routes/web.php:
Route::group(['domain' => '{site}.yourdomain.com', 'middleware' => ['web']], function () {
Route::get('/', '\Aimeos\Shop\Controller\CatalogController@homeAction')
->name('aimeos_home')->where(['site' => '[a-z0-9\-]+']);
Is there anything else that needs to be done? because while loading aimeos1.selldesk.in its loading the default site?
Post by aimeos » 09 Sep 2024, 07:39
If you run "php artisan aimeos:setup --option=setup/default/demo:1 aimeos1.selldesk.in", than the home page of aimeos1.selldesk.in contains the same data as the default home page but it's just a copy. Change the content of the aimeos1.selldesk.in home page to see if there are any changes.
