Error when try to add new tennant in multishop
- AleksandarJovanovic
Php 8.2
Linux
Version 2024.07.
Hello everyone,
I have a problem when trying to add a new tenant in the multi-shop using the command:
php artisan aimeos:setup <site code>.
I get the following error:
No item found for conditions: Array
[locale.site.code] => proba
The new site does not appear in the admin panel, so I can't change the language or add it there.
Thanks in advance.
Linux
Version 2024.07.
Hello everyone,
Thanks in advance.
- Screenshot from 2024-09-25 21-55-17.png (52.51 KiB) Viewed 35821 times
Re: Error when try to add new tennant in multishop
Can you please run "composer up" and try again? That problem should have been fixed recently.
I try that first but the problem still exist. I found another whay that i create first in admin and add locale for new tennant than activate comand for new multi shop. In that way works but on standard way cant create.
If you have idea will be great.
Best regards
Best regards
Sorry, you need to reinstall the Aimeos distribution from scratch because the change was here and this code isn't updated automatically like a package:
https://github.com/aimeos/aimeos/commit ... 4725fc5324
Ok just to install new installation?
Tnx
Tnx
I have installed a completely new installation, and the problem is the same.
Am I making a mistake somewhere?
OK, we've understood the problem now. In the 2024.10 version released in the next days, the setup command will be able to create new sites and add the necessary locale item automatically. You will be also able to configure the language and currently of the locale item (if different from en/USD) by using:
php artisan aimeos:setup --option=setup/language:de --option=setup/currency:EUR testsiteUp to now, this is the way to go. Sorry for the misunderstanding!AleksandarJovanovic wrote: 26 Sep 2024, 09:15 I try that first but the problem still exist. I found another whay that i create first in admin and add locale for new tennant than activate comand for new multi shop. In that way works but on standard way cant create.
Thank you for all support.
Best regards. Alex
Best regards. Alex
