Remove currency from URL in catalogue list
Post by aimeos » 04 Oct 2024, 10:16
If you enable multi-language in the Aimeos distribution, at least the language parameter is then a route attribute:
https://github.com/aimeos#multi-language
MirkoDz
Re: Remove currency from URL in catalogue list
Post by MirkoDz » 04 Oct 2024, 10:28
Is there a way to exclute query locale and currency, and append then as url prefixes and than use them where needed?
Currently I am developing Laravel app and those pages are not translated when language is switched, and I do not want to have
site-url.test?locale=rs&&currency=RSD
but rather
site-url.test/rs/rsd/
Post by aimeos » 04 Oct 2024, 10:50
You can change the route prefix to '{locale}/{currency}/' but you have to make sure that the currency is always available when the route is generated: https://github.com/aimeos/aimeos/blob/2 ... hp#L80-L87
