Adjusting "f_search" in Aimeos for Product Search Behavior
randomdennis
Post by randomdennis » 10 Oct 2024, 12:56
Hi everyone,
I'm using Aimeos's JSONAPI with f_search and noticed something peculiar. When I search for "control sauna," I don't get any results, but when I search for "sauna control" I do. The products have the words "sauna" "saunacontrol" and "control" individually in the title or text.
I would like to adjust how f_search queries the database. Does anyone know where I can modify this behavior? I'm looking for both code-based and configuration-based solutions (e.g., Elastic vs. standard settings).
Thanks in advance for any help!
Re: Adjusting "f_search" in Aimeos for Product Search Behavior
Post by aimeos » 10 Oct 2024, 13:11
Where do you store the product index? MySQL, PostGreSQL, Solr or ElasticSearch?
Post by aimeos » 10 Oct 2024, 14:15
The MySQL index text manager generates a "MATCH( mindte."content" ) AGAINST( '...' IN BOOLEAN MODE )" statement here:
https://github.com/aimeos/aimeos-core/b ... hp#L25-L30
You can set the log level to 7 (debug) and have a look into the Log panel of the admin backend which SQL statements are used:
https://github.com/aimeos/aimeos/blob/m ... p.php#L247
The MATCH statement should look like this:
MATCH( mindte."content" ) AGAINST( 'control* sauna*' IN BOOLEAN MODE )
This should find products whose texts contain words starting with "control" or "sauna", so "saunacontrol" should be found provided the mshop_index_text.content column contains those words.
randomdennis
Post by randomdennis » 07 May 2025, 13:50
We added a ProductSearch DB Table with dublicate product entries for every categorie based on catid, which works super fast.
