Start date and End date in Price rule is not persistent.
Paulus-Ragnarr
Post by Paulus-Ragnarr » 25 Oct 2024, 07:35
Hi community,
I’m encountering an issue with the start and end dates on a price rule. After creating a price rule with specific start and end dates, everything seems to work as expected. However, when I open the price rule details, the start and end date fields appear empty.
Is there a way to ensure that these dates persist and display correctly in the details view? Thanks in advance for your help!
Re: Start date and End date in Price rule is not persistent.
Post by aimeos » 25 Oct 2024, 09:46
Thank you for your hint! The problem has been fixed and a new version of the aimeos/ai-admin-jqadm package released.
Paulus-Ragnarr
Post by Paulus-Ragnarr » 26 Oct 2024, 09:07
Hello thank you for the fix :D Can I ask what version? Is it dev-master?
I am using Aimeos Headless version
Post by aimeos » 26 Oct 2024, 09:55
It's 2024.10.x
Paulus-Ragnarr
Post by Paulus-Ragnarr » 07 Nov 2024, 11:28
Hi Aimeos,
Would it be possible to apply this fix to version 2024.07.x as well? We’re currently using that version and would greatly appreciate the update.
Thank you!
Post by aimeos » 07 Nov 2024, 11:36
Sorry, but 2024.07 isn't supported any more: https://aimeos.org/roadmap
Only the LTS version is supported for 1.5 year after release. The stable release before (2024.04 and 2024.07) are only supported until the LTS version has been released. Please update to 2024.10 LTS, it should be possible without problems.
