Add main Categories similar to the Home Default category
afoster009
Post by afoster009 » 11 May 2016, 17:45
Hello, i am wondering how i might create a main category that functions the same way as the "Home" Default category.
for example i want a main category called Hoses which has sub categories for the different types of hoses. right now i can only add categories as sub categories to the home category
Re: Add main Categories similar to the Home Default category
Post by aimeos » 12 May 2016, 00:58
If you want to show a specific category by default, you can configure one with
https://aimeos.org/docs/Configuration/C ... id-default
