Percona-XtraDB-Cluster doesn't recommend use of DML command on a table (mshop_index_supplier)
kopz
Post by kopz » 15 Nov 2024, 14:24
Any reason why some tables don't have a primary key (mshop_index_price, mshop_index_supplier ...) ? I'd just like to know if I can safely make migrations on these tables to alter prodid into PK without any side effects.
{"log":"2024-11-13T09:21:08.071343Z 38589 [Warning] [MY-000000] [WSREP] Percona-XtraDB-Cluster doesn't recommend use of DML command on a table (b2bshop.mshop_index_supplier) without an explicit primary key with pxc_strict_mode = PERMISSIVE\n","file":"/var/lib/mysql/mysqld-error.log"}
Re: Percona-XtraDB-Cluster doesn't recommend use of DML command on a table (mshop_index_supplier)
Post by aimeos » 15 Nov 2024, 15:47
The index tables doesn't need primary keys and you can't add primary keys to existing columns as this will likely lead to insert errors during index rebuild.
kopz
Post by kopz » 18 Nov 2024, 08:07
What about adding a new column (PK AI) without altering any of the existing columns?
Thanks for the answers.
Post by aimeos » 18 Nov 2024, 13:11
Would be superfluous because it would be not used at all. Remember that this is only a recommendation which is not necessary or helpful in that case. When does it appear in the logs? When you run the migration tasks?
