How to Include Property Labels in Product Property Attributes Using JSON:API?
Paulus-Ragnarr
Post by Paulus-Ragnarr » 25 Nov 2024, 06:06
Hi Aimeos,
I’m working on a JS frontend and focusing on product details, particularly product properties. Is there a way to include the property label within the product property attributes using the JSON:API include?
The reason is that formatting product.property.type directly in the frontend has been challenging. Including the property label would make the process much more straightforward.
Thanks in advance!
Screenshot 2024-11-25 at 1.58.53 PM.png (90.76 KiB) Viewed 48429 times
Screenshot 2024-11-25 at 12.09.40 PM.png (69.18 KiB) Viewed 48429 times
Re: How to Include Property Labels in Product Property Attributes Using JSON:API?
Post by aimeos » 25 Nov 2024, 14:44
You need Aimeos 2024.10.x and use "include=product.property,product.property.type". Then, the "included" section contains a type item related to the property item.
PaoloLegaspi
Post by PaoloLegaspi » 26 Nov 2024, 08:14
Hello thanks for the reply.
I’ve updated from version 2024.07.x to 2024.10.x as you suggested and included the query "product,product/property,product/property/type". However, the response still doesn’t include the property label or the product property type.
Are there any additional configurations I need to set up to get these values?
Thanks!
Post by aimeos » 28 Nov 2024, 14:00
Can you please update the JSON:API package to get the required bugfix by executing:
composer req aimeos/ai-client-jsonapi:2024.10.x-dev
Then, use "include=product.property,product.property.type" to get the product properties and their types.
