Get Prices of Attributes
Moritz
Post by Moritz » 22 Nov 2024, 12:16
In my template I call $attr->getRefItems('price', null, 'default') in the foreach loop and get no prices.
The attribute $attr generally has no ref items.
$productItem = $this->get('productItem', null);
if (isset($productItem)) {
    $attrPrices = [];
    $attributes = $productItem->getRefItems('attribute', null, 'hidden');
    foreach ($attributes as $attr) {
        $attrPrices = array_merge($attrPrices, $attr->getRefItems('price', null, 'default')->toArray());
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: Get Prices of Attributes added by Supplier
Post by aimeos » 25 Nov 2024, 11:40
Check if the hidden attributes assigned to the product have prices and if they are loaded by passing the correct referenced domains (at least ['attribute', 'price'] in your case).
Moritz
Post by Moritz » 25 Nov 2024, 14:13
Yes the hidden attributes have prices and are assigned to the product.
In my code example you see how I try to load the prices of the attributes but I get nothing.
I use your ai-customergroups v24.10.2 extension and found out, that it works when I disable the extension.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 25 Nov 2024, 14:23
Can you please execute
composer req aimeoscom/ai-customergroups:2024.10.x-dev
and run the setup tasks again? The "key" column wasn't migrated correctly.
Moritz
Post by Moritz » 27 Nov 2024, 15:03
We have already written a lot on Github about the migration of ai-customergroups.
That works now.
But when the ai-customergroups extension is active, I don't get any prices from the attribute in this line from my code example above.
When I disable ai-customergroups it works and I get prices.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 28 Nov 2024, 11:56
Tested locally with ai-customergroups:2024.10.x-dev installed by adding a hidden attribute with a price to a product and fetching/displaying it in the catalog detail view worked without problems. The pure existence of the ai-customergroups extension can't be the reason for that. Did you assign a customer or group to that price of the hidden attribute?
Make sure, you've installed the latest aimeos/aimeos-typo3:2024.10.x-dev release because the Aimeos TYPO3 extension has an unreleased fix for group handling.
Moritz
Post by Moritz » 28 Nov 2024, 16:26
I have tested with 2024.10.x-dev version of Aimeos and ai-customergroups aswell.
In the checkItem() function of CustomerGroup you can see, that the item has no listItems.
But in the backend this attribute has a price item assigned.
When I comment out this lines (disable ai-customergroups) I get the price of the attribute correctly.
plugin.tx_aimeos.settings.mshop.attribute.manager.decorators.global.CustomerGroup = CustomerGroup
plugin.tx_aimeos.settings.mshop.catalog.manager.decorators.local.CatalogCustomerGroup = CatalogCustomerGroup
plugin.tx_aimeos.settings.mshop.index.manager.decorators.local.IndexCustomerGroup = IndexCustomerGroup
plugin.tx_aimeos.settings.mshop.media.manager.decorators.global.CustomerGroup = CustomerGroup
plugin.tx_aimeos.settings.mshop.price.manager.decorators.global.CustomerGroup = CustomerGroup
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 29 Nov 2024, 14:23
The problem is that this TypoScript configuration overwrites the default decorators:
When using these line, it works as expected:
plugin.tx_aimeos.settings.mshop.attribute.manager.decorators.global {
  Lists = Lists
  Property = Property
  Type = Type
plugin.tx_aimeos.settings.mshop.catalog.manager.decorators.local {
plugin.tx_aimeos.settings.mshop.index.manager.decorators.local {
plugin.tx_aimeos.settings.mshop.media.manager.decorators.global {
  Lists = Lists
  Property = Property
  Type = Type
plugin.tx_aimeos.settings.mshop.price.manager.decorators.global {
  Lists = Lists
  Property = Property
  Type = Type
Moritz
Post by Moritz » 02 Dec 2024, 09:46
With that TypoScript it works.
Maybe you can change the instruction in README.md of ai-customergroups.
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 02 Dec 2024, 09:47
That have already been updated in the latest version of the extension
