How to Change Image Preview Ratio
randomdennis
Post by randomdennis » 13 Dec 2024, 13:25
Hello, in version 2024 the preview configuration has been moved. Some of my images are no longer scaled 4/3 but 3/4.
I have tried in my extension under config/mshop/media.php
to overwrite:
<?php
return array(
'manager' => array(
'previews' => [
'common' => [[
'maxwidth' => 960,
'maxheight' => 720,
'force-size' => 0,
'catalog' => [
'stage' => [[
'maxwidth' => 960,
'maxheight' => 720,
'force-size' => 0,
'product' => [[
'maxwidth' => 960,
'maxheight' => 720,
'force-size' => 0,
I also ran the scale planner and set “--ai-product-image-ratio” to 4/3 in the backend settings, but like 60% of the images are wrong scale
Re: How to Change Image Preview Ratio
Post by aimeos » 16 Dec 2024, 13:14
If you add that to the PHP config file, it's merged into the existing configuration. Then, it's only overwritten if the array key (0, 1, 2, 3) is the same. This doesn't apply if you set the configuration via TypoScript in the scheduler task and for the admin backend module.
randomdennis
Post by randomdennis » 17 Dec 2024, 10:50
Apparently it cannot find some pictures although they are available
Scaling media item "10035" failed: Couldn't read file "/uploads/tx_aimeos/1.d/files/f/3/f354eb3f_5x70.jpg"
randomdennis
Post by randomdennis » 18 Dec 2024, 14:47
What I found is that in Scale/Standard.php, the rescale function always returns a path via getUrl() like this:
files/e/a/ea5f2aee2c2ca9ee3e743f3a9cf8043e.png
However, for some items, I get paths like:
/uploads/tx_aimeos/files/d/9/d96f61617ee606ba537b3f751a9e13c1.jpg
These files are not found or read correctly.
If I use this code in the scale function within typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/src/MShop/Media/Manager.php, it works:
if (strncmp($url, '/uploads/tx_aimeos/', 19) === 0) {
$url = substr($url, 19);
I’m not sure if this is a specific issue just for us. Thanks again!
Post by aimeos » 15 Jan 2025, 09:28
Having /uploads/tx_aimeos/ prefix in the file path is wrong. Do you know where this comes from?
