Upgrade from 2021 to 2024
eljacko
Post by eljacko » 13 Dec 2024, 17:19
System: Mac
Laravel: 8
Aimeos/laravel: 2021
I have this old aimeos project which i need to upgrade to the 2024 version.
My plan was to install a new project with laravel 10 or 11 and aimeos 2024, then do the setup for upgrading the database.
After that i wanted to rebuild the theme from scratch.
Is this possible, to migrate the database directly to 2024 or do i have to do some migrations of the version between?
Re: Upgrade from 2021 to 2024
Post by aimeos » 13 Dec 2024, 17:38
Migrating the database from 2021.10 to 2024.10 should be possible without problems
