Aimeos:setup error after Composer update
PaoloLegaspi
Post by PaoloLegaspi » 23 Dec 2024, 05:37
Hi, we had encountered an error while we are doing php artisan aimeos:setup after composer update
Aimeos version: Aimeos Headless 2024.10.*
PHP version: 8.2
Environment: Mac
Re: Aimeos:setup error after Composer update
Post by aimeos » 23 Dec 2024, 10:46
Sorry, has been fixed now in the latest core package
PaoloLegaspi
Post by PaoloLegaspi » 26 Dec 2024, 16:09
Hello, thank you for the update!
We've encountered an issue again while running php artisan aimeos:setup and php artisan aimeos:setup --option=setup/default/demo:0. However, when we use php artisan aimeos:setup --option=setup/default/demo:1, the error doesn’t occur. We’d like to use php artisan aimeos:setup for our new upscheme task, but we’re unable to migrate the new table.
Screenshot 2024-12-27 at 12.06.55 AM.png (128.75 KiB) Viewed 23963 times
Post by aimeos » 28 Dec 2024, 10:28
Can you please update to the latest 2024.10.x-dev version? This should fix the issue if there are no records in the mshop_order table
