Categories instead of Products? (trying to add multiple products to category)
alexkereszturi
Post by alexkereszturi » 24 Dec 2024, 11:21
Hi forum!
Trying to add products to a category (using Typo3). When searching for a product it lists categories: (see png)
Bug? Can I "debug" that on our side somehow? Maybe anyone changed a file he shouldn't.
Thx for any hint.
Re: Categories instead of Products? (trying to add multiple products to category)
Post by aimeos » 24 Dec 2024, 11:26
Which Aimeos version do you use?
alexkereszturi
Post by alexkereszturi » 31 Dec 2024, 01:59
Aimeos: 23.10.8
Additional Info: the "same same" happens when trying to add products to suppliers => suppliers are listed instead of products :roll:
Post by aimeos » 02 Jan 2025, 14:37
What's the network request when the "product" selector opens to list the suggestions? Please have a look into the network console of your browser.
Post by aimeos » 23 Jan 2025, 09:41
The URL looks OK and should return categories. Is that the case in the response?
alexkereszturi
Post by alexkereszturi » 27 Jan 2025, 02:50
Yes, the response delivers categories. But it shold deliver products.
So the query is ok ... but it's the wrong query for the task: I want to add a product to a category!
Post by aimeos » 27 Jan 2025, 15:21
The Javascript that fetches the items is here:
https://github.com/aimeos/ai-admin-jqad ... #L370-L402
The "domain" seems to be used wrongly and nobody noticed that up to now. Can you replace it with the code below and check if it works?
			suggest(input, loadfcn) {
				const self = this;
				const args = {
					'filter': {'||': [
					'fields': {},
					'page': {'offset': 0, 'limit': 25},
					'sort': 'product.label'
				args['filter']['||'][0]['==']['product.id'] = input;
				args['filter']['||'][1]['=~']['product.code'] = input;
				args['filter']['||'][2]['=~']['product.label'] = input;
				args['fields']['product'] = ['product.id', 'product.code', 'product.label'];
				try {
					loadfcn ? loadfcn(true) : null;
					this.get('product', args, function(data) {
						self.options = [];
						(data.items || []).forEach(function(entry) {
							self.options.push({
								'id': entry['product.id'],
								'label': entry['product.id'] + ' - ' + entry['product.label'] + ' (' + entry['product.code'] + ')'
				} finally {
					loadfcn ? loadfcn(false) : null;
alexkereszturi
Post by alexkereszturi » 28 Jan 2025, 15:00
the code change works! thanks!
Will it be in the next release/update?
Post by aimeos » 29 Jan 2025, 10:29
It has been fixed now. Please update the aimeos/ai-admin-jqadm package to "2023.10.x-dev"
