Order state cannot be saved
OSilbe
Post by OSilbe » 14 Jan 2025, 06:46
After moving the shop (Typo3 V.8, Shop V.18.10.2) to a new server with PHP 7.4 running, changing the order state cannot be saved. Changes are not saved to database. No error message in PHP-log and Shop-log. Has anyone a solution for this problem.
PHP version on the previous server was 7.0.33 but on the new server only PHP 7.4 is available.
Current server is:
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
Admin GUI:
Plesk Obsidian 18.0.65 Update 2
Web Pro Edition
Re: Order state cannot be saved
Post by aimeos » 14 Jan 2025, 09:10
No known issues but most likely, no one did such an update before. You have to upgrade to a supported LTS version as soon as possible because that version has security issues and isn't even supported by ELTS any more.
