How to customize default values in add form (admin backend)?
bar_on
Post by bar_on » 19 Jan 2025, 10:50
When creating new product, I want the tax rate in all new price to be 0 by default, also currency to be EUD. Is there a way I can achieve this easily?
Version:
"aimeos/aimeos-laravel": "~2023.10",
"php": "^8.1.0",
Re: How to customize default values in add form (admin backend)?
Post by aimeos » 20 Jan 2025, 10:01
You can create datasets which automatically adds a price with the values when selected:
https://aimeos.org/docs/2024.x/config/a ... t/#product
If EUD is the only currency you use, then you should deactivate all other currencies the EUD is selected by default
