How to define correct ISO-Code?
alexkereszturi
Post by alexkereszturi » 27 Jan 2025, 02:59
Definig a language in the backend needs the ISO-code in "de_CH" Format. (001.png)
Trying to save it as "de-CH" delivers an error: 002.png
But "de_CH" invokes an error "Incorrect locale information provided" in basket-mini.js (003.png) which might be explainable as https://developer.mozilla.org/en-US/doc ... mberFormat defines ISO-Codes with "-" and not with "_" => "de-CH" instead of "de_CH".
How can I get the basket-mini.js running again with "de_CH" ?
Re: How to define correct ISO-Code?
Post by aimeos » 27 Jan 2025, 14:49
HTML defines a different separator than the ISO codes. To fix that change the line to:
currency: attr['order.currencyid'].replace(/_/g, '-'),
We've done that in the core files too now.
