Cant filter producst by multiple categories
rmdaniel
Post by rmdaniel » 03 Feb 2025, 09:14
Hi, Im having some issue, that i can not filter products by multiple categories, for example i have 10 items in category A and 3 in category B, I want to show items only which are in both A and B.
I was trying to add some code to vendor/aimeos/ai-controller-frontend/src/Controller/Frontend/Product/Standard.php on aimeos 2023.10
But none was working for me, no products was given back, while there should be at least 2.
			$expr = [];
			foreach($ids as $catid) {
					$func = $this->filter->make('product:has', ['index.catalog.id', 'default', $catid]);
					$expr[] = $this->filter->compare( '==', $func, 0 );
			$addFilter = $this->filter->and($expr);
			$this->addExpression($addFilter);
or this one:
			 $this->addExpression( $this->filter->and( [
			 	$this->filter->compare( '==', 'index.catalog.id', $ids[0] ),
			 	$this->filter->compare( '==', 'index.catalog.id', $ids[1] )
$ids are = [130, 79].
This line is commented out:
//$this->addExpression( $this->filter->compare( '==', 'index.catalog.id', $ids ) );
Thanks!
Re: Cant filter producst by multiple categories
Post by aimeos » 04 Feb 2025, 13:48
By default, categories are OR combined if you hand over a list of IDs. Changing this to a AND combination is a bit more difficult due to how relational databases work.
First, you have to add a new search function to the product manager by creating a decorator (only add getSearchAttributes()):
https://aimeos.org/docs/2023.x/models/e ... /#easy-way
The search function must be counting the records is a sub-select like this one:
https://github.com/aimeos/aimeos-core/b ... #L288-L297
Then, you can use that search function in your custom product frontend controller. Extend from the Standard class in your own extension, overwrite the category() method there and configure the new class name:
- https://github.com/aimeos/ai-controller ... #L227-L254
- https://aimeos.org/docs/2023.x/config/c ... duct/#name
