How can I choose Domain's type of stock? (right question: how to import only stocks qty?)
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 05 Mar 2025, 18:28
Try to do my last steps for importing items, but has stopped at final cell of csv file.
What I do:
1) Create csv file with full informations, unclude price, all texts and stock's quantity:
2) At test machine (with SQL DB) - all is working fine (but not select stock from stock's domain).
At ES site - import can't finish:
I remember that you have write about this - ES work with total data (document's type of DB).
3) One new Stock was create, but not at stock's domaine:
I have read Instruction and how I can understand - by default at Aimeos not open "stock" domain for import/export - right?
Maybe I can add one more parameter at shop.php file for choose right domain type? Like for attribute:
'attribute' => [
        61 => 'attribute.list.type',
        62 => 'attribute.code',  // 1
        63 => 'attribute.label',
        64 => 'attribute.code',  // 2
        65 => 'attribute.label',
	66 => 'attribute.code',  // 3
        67 => 'attribute.label',
        68 => 'attribute.code',  // 4
        69 => 'attribute.label',
        70 => 'attribute.code',  // 5
        71 => 'attribute.label',
or it is only one way - add stock domain to mshop?
P.S.: Deepseek say that I need to add:
but I don't trust him :roll:
Last edited by ЕвгенияСемихова(ИПСемиховаЕ.А.) on 06 Mar 2025, 22:30, edited 1 time in total.
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Re: How can I choose Domain's type of stock?
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 06 Mar 2025, 22:28
After add second job of import prices I think I have found problem solution. Will try after some sleep.
Re: How can I choose Domain's type of stock? (right question: how to import only stocks qty?)
Post by aimeos » 07 Mar 2025, 11:39
ЕвгенияСемихова(ИПСемиховаЕ.А.) wrote: 05 Mar 2025, 18:28 1) Create csv file with full informations, unclude price, all texts and stock's quantity:
Adding stock levels to product CSV doesn't work for ES because there's no generated product ID for the documents until they are stored in ES. Use the separate stock/import/csv job controller instead.
ЕвгенияСемихова(ИПСемиховаЕ.А.) wrote: 05 Mar 2025, 18:28 3) One new Stock was create, but not at stock's domaine:
That was a bug fixed now in ai-controller-jobs dev-master and 2024.10.x-dev.
ЕвгенияСемихова(ИПСемиховаЕ.А.) wrote: 05 Mar 2025, 18:28 P.S.: Deepseek say that I need to add:
It lies when it comes to Aimeos related code like most other AIs :-/
