[SOLVED] Problem to import products (csv)
heural
Post by heural » 19 Mar 2025, 15:03
Hi Aimeos-Team,
I have this error today for the product import:
Unable to import product with code "7370": Aimeos\MShop\Stock\Item\Standard::setProductId(): Argument #1 ($value) must be of type string, null given, called in /var/www/html/vendor/aimeos/aimeos-core/src/MShop/Stock/Item/Standard.php on line 147
We have nothing changed these days at our imports, so i´ve checked out:
Downgrading aimeos/ai-controller-jobs (2024.10.6 => 2024.10.5
The import works again, so there must be a bug in ai-controller-jobs:2024.10.6 ..?
Best regards!
Ralf
Thanks a lot!
Re: Problem to import products (csv)
Post by aimeos » 19 Mar 2025, 18:33
Thanks for your hint! The problem has been solved now in dev-master and 2024.10.x-dev.
Can you please run "composer req aimeos/ai-controller-jobs:2024.10.x-dev" and test if it works for your too?
heural
Post by heural » 20 Mar 2025, 09:17
Thank you for the fix, it works!
Thanks a lot!
