Missing Required Parameter for Route: aimeos_shop_account - URI: {site}/profile
hussain.h.ff32
Post by hussain.h.ff32 » 10 Apr 2025, 01:21
Issue:
I'm encountering the following error on my Laravel 12.8.1 application with Aimeos 2024 and PHP 8.4.2:
Missing required parameter for [Route: aimeos_shop_account] [URI: {site}/profile] [Missing parameter: site].
I followed the Aimeos documentation for multi-shop configuration and tried setting up the routes as shown below:
use App\Http\Controllers\ProfileController;
use Illuminate\Support\Facades\Route;
Route::get("/", function () {
return view("welcome");
Route::get("/dashboard", function () {
return view("dashboard");
->middleware(["auth", "verified"])
->name("dashboard");
Route::middleware("auth")->group(function () {
Route::get("{site}/profile", [ProfileController::class, "edit"])->name("aimeos_shop_account");
Route::patch("{site}/profile", [ProfileController::class, "update"])->name("profile.update");
Route::delete("{site}/profile", [ProfileController::class, "destroy"])->name("profile.destroy");
require __DIR__ . "/auth.php";
Route::group(["middleware" => ["web"]], function () {
Route::get("/", "\Aimeos\Shop\Controller\CatalogController@homeAction")->name("aimeos_home");
Route::get("/{site?}", function ($site = "default") {
request()->merge(["site" => $site]);
return app(\Aimeos\Shop\Controller\CatalogController::class)->homeAction();
})->where("site", "[a-zA-Z0-9_-]+");
'routes' => [
'jsonapi' => ['prefix' => '{site}/jsonapi', 'middleware' => ['web', 'api']],
'account' => ['prefix' => '{site}/profile', 'middleware' => ['web', 'auth']],
'default' => ['prefix' => '{site}/shop', 'middleware' => ['web']]
Environment Details:
Laravel Version: 12.8.1
PHP Version: 8.4.2
Aimeos Version: 2024
Operating System: Linux
I followed the multi-shop setup in the documentation, but I keep getting the "Missing required parameter: site" error when trying to access the profile route for the shop.
Re: Missing Required Parameter for Route: aimeos_shop_account - URI: {site}/profile
Post by aimeos » 10 Apr 2025, 07:32
The Aimeos shop distribution is already prepared for multi-site setups:
https://github.com/aimeos/#installation
If you need to integrate Aimeos into an existing application and add multi-tenancy, please have a look here:
- https://github.com/aimeos/aimeos/blob/m ... hp#L49-L54
- https://github.com/aimeos/aimeos/blob/m ... php#L8-L21
hussain.h.ff32
Post by hussain.h.ff32 » 10 Apr 2025, 18:29
Am using laravel package are you able to help me to fix this issue is there a way to fix it !
Post by aimeos » 11 Apr 2025, 07:21
Your routes are wrong, please have a look at the links.
Also, you have to use airoute() instead of route() in all your templates.
hussain.h.ff32
Post by hussain.h.ff32 » 15 Apr 2025, 12:07
I've listened to your advice and used the quick installation for aimeos but am facing many issues 😮‍💨 first of all I've enabled the multiple shop and local and I have the default shop also I've created seller as well I've followed all of the instructions but now I cannot access the admin panel Illuminate
Routing
Exceptions
UrlGenerationException
PHP 8.2.28
12.8.1
Missing required parameter for [Route: login] [URI: {locale}/{site}/login] [Missing parameter: locale].
<?php
$multishop = $multiroute = [];
$prefix = env('SHOP_MULTILOCALE') ? '{locale}/' : '';
if (env('SHOP_MULTISHOP')) {
$multishop = ['routes' => [
'admin' => ['prefix' => 'admin', 'middleware' => ['web', 'auth', 'verified']],
'jqadm' => ['prefix' => 'admin/{site}/jqadm', 'middleware' => ['web', 'auth', 'verified']],
'graphql' => ['prefix' => 'admin/{site}/graphql', 'middleware' => ['web', 'auth', 'verified']],
'jsonadm' => ['prefix' => 'admin/{site}/jsonadm', 'middleware' => ['web', 'auth', 'verified']],
'account' => ['prefix' => $prefix . '{site}/profile', 'middleware' => ['web', 'auth', 'verified']],
'default' => ['prefix' => $prefix . '{site}/shop', 'middleware' => ['web']],
'basket' => ['prefix' => $prefix . '{site}/shop', 'middleware' => ['web']],
'checkout' => ['prefix' => $prefix . '{site}/shop', 'middleware' => ['web']],
'confirm' => ['prefix' => $prefix . '{site}/shop', 'middleware' => ['web']],
'supplier' => ['prefix' => $prefix . '{site}/s', 'middleware' => ['web']],
'page' => ['prefix' => $prefix . '{site}/p', 'middleware' => ['web']],
'home' => ['prefix' => $prefix . '{site}', 'middleware' => ['web']],
'update' => ['prefix' => '{site}'],
return array_replace_recursive($multiroute, $multishop + [
'apc_enabled' => false,
'apc_prefix' => 'aimeos:',
'num_formatter' => 'Locale',
'pcntl_max' => 4,
'version' => env('APP_VERSION', 1),
'roles' => ['admin', 'editor', 'super'],
'panel' => 'dashboard',
'admin' => [
'jqadm' => [
'site' => [
'groups' => ['admin', 'super'], // groups allowed to change site
'resource' => [
'site' => [
'groups' => ['admin', 'super','editor'], // groups allowed to change site
'site' => [
'default' => [
'locale' => [
'language' => 'en',
'currency' => 'USD',
'theme' => 'default',
'seller' => [
'locale' => [
'language' => ['en', 'ar'],
'currency' => ['USD', 'EUR'],
'theme' => 'site1',
// Add more sites as needed
'routes' => [
'jsonapi' => ['prefix' => 'jsonapi', 'middleware' => ['web', 'api']],
'account' => ['prefix' => $prefix . 'profile', 'middleware' => ['web', 'auth']],
'default' => ['prefix' => $prefix . 'shop', 'middleware' => ['web']],
'basket' => ['prefix' => $prefix . 'shop', 'middleware' => ['web']],
'checkout' => ['prefix' => $prefix . 'shop', 'middleware' => ['web']],
'confirm' => ['prefix' => $prefix . 'shop', 'middleware' => ['web']],
'supplier' => ['prefix' => $prefix . 's', 'middleware' => ['web']],
'page' => ['prefix' => $prefix . 'p', 'middleware' => ['web']],
'home' => ['prefix' => $prefix, 'middleware' => ['web']],
'update' => [],
'where' => [
'site' => '[A-Za-z0-9\.\-]+',
'locale' => '[a-z]{2}(\_[A-Z]{2})?',
'page' => [
'account-index' => ['locale/select', 'basket/mini','catalog/tree','catalog/search','account/profile','account/review','account/subscription','account/basket','account/history','account/favorite','account/watch','catalog/session'],
'basket-index' => ['locale/select', 'catalog/tree','catalog/search','basket/standard','basket/bulk','basket/related'],
'catalog-count' => ['catalog/count'],
'catalog-detail' => ['locale/select', 'basket/mini','catalog/tree','catalog/search','catalog/stage','catalog/detail','catalog/session'],
'catalog-home' => ['locale/select','basket/mini','catalog/tree','catalog/search','catalog/home', 'cms/page'],
'catalog-list' => ['locale/select','basket/mini','catalog/filter','catalog/tree','catalog/search','catalog/price','catalog/supplier','catalog/attribute','catalog/session','catalog/stage','catalog/lists'],
'catalog-session' => ['locale/select','basket/mini','catalog/tree','catalog/search','catalog/session'],
'catalog-stock' => ['catalog/stock'],
'catalog-suggest' => ['catalog/suggest'],
'catalog-tree' => ['locale/select','basket/mini','catalog/filter','catalog/tree','catalog/search','catalog/price','catalog/supplier','catalog/attribute','catalog/session','catalog/stage','catalog/lists'],
'checkout-confirm' => ['catalog/tree','catalog/search','checkout/confirm'],
'checkout-index' => ['locale/select', 'catalog/tree','catalog/search','checkout/standard'],
'checkout-update' => ['checkout/update'],
'supplier-detail' => ['locale/select','basket/mini','catalog/tree','catalog/search','supplier/detail','catalog/lists'],
'cms' => ['basket/mini','catalog/tree','cms/page'],
'resource' => [
'db' => [
'adapter' => config('database.connections.' . config('database.default', 'mysql') . '.driver', 'mysql'),
'host' => config('database.connections.' . config('database.default', 'mysql') . '.host', '127.0.0.1'),
'port' => config('database.connections.' . config('database.default', 'mysql') . '.port', '3306'),
'socket' => config('database.connections.' . config('database.default', 'mysql') . '.unix_socket', ''),
'database' => config('database.connections.' . config('database.default', 'mysql') . '.database', 'forge'),
'username' => config('database.connections.' . config('database.default', 'mysql') . '.username', 'forge'),
'password' => config('database.connections.' . config('database.default', 'mysql') . '.password', ''),
'stmt' => config('database.default', 'mysql') === 'mysql' ? ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"] : [],
'limit' => 3,
'defaultTableOptions' => [
'charset' => config('database.connections.' . config('database.default', 'mysql') . '.charset'),
'collate' => config('database.connections.' . config('database.default', 'mysql') . '.collation'),
'driverOptions' => config('database.connections.' . config('database.default', 'mysql') . '.options'),
'fs' => [
'adapter' => 'Standard',
'tempdir' => storage_path('tmp'),
'basedir' => public_path(),
'baseurl' => rtrim(env('ASSET_URL', PHP_SAPI == 'cli' ? env('APP_URL') : ''), '/'),
'fs-media' => [
'basedir' => public_path('aimeos'),
'baseurl' => rtrim(env('ASSET_URL', PHP_SAPI == 'cli' ? env('APP_URL') : ''), '/') . '/aimeos',
'fs-mimeicon' => [
'basedir' => public_path('vendor/shop/mimeicons'),
'baseurl' => rtrim(env('ASSET_URL', PHP_SAPI == 'cli' ? env('APP_URL') : ''), '/') . '/vendor/shop/mimeicons',
'fs-theme' => [
'basedir' => public_path('vendor/shop/themes'),
'baseurl' => rtrim(env('ASSET_URL', PHP_SAPI == 'cli' ? env('APP_URL') : ''), '/') . '/vendor/shop/themes',
'admin' => [
'jqadm' => [
'url' => [
'copy' => ['target' => 'aimeos_shop_jqadm_copy'],
'create' => ['target' => 'aimeos_shop_jqadm_create'],
'delete' => ['target' => 'aimeos_shop_jqadm_delete'],
'export' => ['target' => 'aimeos_shop_jqadm_export'],
'get' => ['target' => 'aimeos_shop_jqadm_get'],
'import' => ['target' => 'aimeos_shop_jqadm_import'],
'save' => ['target' => 'aimeos_shop_jqadm_save'],
'search' => ['target' => 'aimeos_shop_jqadm_search'],
'client' => [
'html' => [
'basket' => [
'cache' => [
'enable' => true,
'common' => [
'cache' => [
'enable' => true,
'catalog' => [
'lists' => [
'cache' => [
'enable' => true,
'controller' => [
'common' => [
'media' => [
'standard' => [
'mimeicon' => [
'directory' => 'vendor/shop/mimeicons',
'madmin' => [
'cache' => [
'manager' => [
'name' => 'None', // Use 'Standard' for production
'mshop' => [
'locale' => [
'site' => env('SHOP_MULTISHOP', false),
Here is the shop.php file please help am stack
Post by aimeos » 15 Apr 2025, 21:38
Please revert your ./config/shop.php to the original file of the Aimeos distribution. Almost all the changes you did are wrong causing the problems. For a multi-shop setup, you only need to adapt the SHOP_* settings in the .env file when using the Aimeos distribution.
