Admin dashboard broken
DavidSlash
Post by DavidSlash » 10 Apr 2025, 13:47
I installed Aimeos on my local, the front end looks good, but when I want to use the admin dashboard:
1) The main dashboard item it doesn't show total orders, completed orders, etc, nor graphics, I only get the spinning wheel on the graphic parts.
2) Clicking options Sales, Catalog, Users, Marketing, Setup, Locales, Languages, does nothing. Not a failed network call, not an error in the console. Nothing.
3) Clicking CMS gives me a Laravel error "No translation directory for domain "admin/ext" available".
The only thing I see on the browser's console is this error:
Uncaught ReferenceError: Aimeos is not defined at en:29:2
Could not establish connection. Receiving end does not exist.
So may be I missed something? This should work right out of the box, right?
Re: Admin dashboard broken
Post by aimeos » 10 Apr 2025, 14:07
Which Aimeos version do you use?
We've released a brand new major release but in our test environment, the admin backend is working like expected.
DavidSlash
Post by DavidSlash » 10 Apr 2025, 14:13
I installed yesterday through github, and this is the composer.json line: "aimeos/aimeos-laravel": "2025.04.*"
Clicking the Aimeos logo on admin I see this on the url: version=2025.04.1
Note: I run Aimeos by doing php artisan serve, may be I need to do it under a docker container?
Post by aimeos » 10 Apr 2025, 14:24
No need for Docker, "artisan serve" should be sufficient.
The CMS issue should be already fixed, can you please run "composer up"?
DavidSlash
Post by DavidSlash » 10 Apr 2025, 20:13
yes! CMS link is already fixed. Yet, other options in dashboard are inaccesible. I add a video for reference: https://drive.google.com/file/d/1T4xbuu ... sp=sharing
Im running a Mac M1 in case that helps.
Post by aimeos » 11 Apr 2025, 07:25
Can you click on the "Uncaught ReferenceError" link and post a screenshot where it occurs?
DavidSlash
Post by DavidSlash » 11 Apr 2025, 14:34
Sure! Here you got!
//Light by default (based on View used) - checks for Dark preference (by browser, or cookie)
if (prefersDark.matches && !isLight) {
    ['light', 'dark'].map(cl => document.body.classList.toggle(cl));
    Aimeos.theme(document.body.classList.contains("dark") ? "dark" : "light") <----- THIS LINE!
document.querySelectorAll(".btn-theme").forEach(item => {
    item.addEventListener("click", function() {
Post by aimeos » 11 Apr 2025, 16:11
Ok, the problem was that you use the dark mode by default.
This is now fixed and a new version tagged. Please run "composer up" again.
DavidSlash
Post by DavidSlash » 11 Apr 2025, 20:24
Perfect! Now it works! I wonder if I got the right Aimeos version... is this version capable of having different vendors each one with a store?
Also, is quite perfect. When I switch to darkmode, it doesn't stick to other sections. But that's just a minor thing.
https://drive.google.com/file/d/1xtgCQU ... sp=sharing
Post by aimeos » 12 Apr 2025, 07:57
Thanks, that problem has been fixed now too and it will be part of the next release.
In the meantime, you can test yourself after executing "composer req aimeos/ai-admin-jqadm:2025.04.x-dev"
For SaaS-like setups, please have a look here:
https://github.com/aimeos#multi-vendor
